Creating a service for an existing booking
When a solution uses the External Service Management option, it is up to the solution to manage the services for bookings. However, for ease of use, the method ServiceManagement.CreateReservationService can be used to create a service for an existing booking. This method will create a service based on the current booking content in the same way as the SRM framework automatically creates a service when a booking is created or started.
This feature is available from SRM 1.2.36 onwards.
using System;
using Skyline.DataMiner.Core.SRM;
using Skyline.DataMiner.Core.SRM.Extensions.Reservations;
using Skyline.DataMiner.Core.SRM.FastBookingCreation;
using Skyline.DataMiner.Net.ResourceManager.Objects;
public class Script
   public static void Run(Engine engine)
      // Replace with reservation guid
      var reservationGuid = Guid.NewGuid();
      var reservation = SrmManagers.ResourceManager.GetReservationInstance(reservationGuid) as ServiceReservationInstance;
      var logger = reservation.GetCachedLogger();
      var bookingManager = reservation.FindBookingManager();
      var srmContext = new SrmManagersContext(engine, bookingManager, reservation, logger);
      ServiceManagement.CreateReservationService(srmContext);
