Silently editing a pending booking
If a booking has not yet started, you can use the TryEditBooking method to silently edit its content.
The example below shows how you can use this to update the name of a booking.
using System;
using Skyline.DataMiner.Core.SRM;
using Skyline.DataMiner.Core.SRM.Extensions.Reservations;
public class Script
// to be replaced with reservation guid;
var reservationId = Guid.Parse("<Reservation ID>");
var reservation = SrmManagers.ResourceManager.GetReservationInstance(reservationId);
var bookingManager = reservation.FindBookingManager();
var bookingData = reservation.GetBookingData();
bookingData.Description = "new booking description";
// TryEditBooking is available since 1.2.21. In earlier versions EditBooking can be used as an alternative.
var result = bookingManager.TryEditBooking(engine, reservation.ID, bookingData, null, null, null, null, out reservation);
The example below show how you can use this to update the name and the resource assigned to node 1:
using System;
using System.Linq;
public class Script
var functionData = reservation.GetFunctionData();
functionData.Single(x => x.Id == 1 /* Node ID */).SelectedResource = "new resource guid";
var result = bookingManager.TryEditBooking(engine, reservation.ID, bookingData, functionData, null, null, null, out reservation);
