Silently extending the timing of a booking
The example below shows how the timing of a booking can be extended without user interaction by means of an automation script.
using System;
using Skyline.DataMiner.Core.SRM;
using Skyline.DataMiner.Core.SRM.Extensions.Reservations;
using Skyline.DataMiner.Core.SRM.Model.ReservationAction;
public class Script
   public static void Run(Engine engine)
      // Replace with reservation guid
      var reservationGuid = Guid.NewGuid();
      var reservation = SrmManagers.ResourceManager.GetReservationInstance(reservationGuid);
      var bookingManager = reservation.FindBookingManager();
      var extendBookingInputData = new ExtendBookingInputData
         IsSilent = true,
         TimeToAdd = TimeSpan.FromHours(1),
      var result = bookingManager.TryExtend(engine, ref reservation, extendBookingInputData);
