Silently removing a resource and node from a booking and potentially creating a new service definition
When a resource has to be removed from a booking and the service definition with the associated node also has to be removed, you can use the TryRemoveAndNode method.
In case there is no matching service definition that can cope with the updated list of resources in the booking, DataMiner SRM will try to identify another service definition or create a new one.
Here is a code sample:
using System;
using Skyline.DataMiner.Core.SRM;
using Skyline.DataMiner.Core.SRM.Extensions.Reservations;
public class Script
      // Update with relevant data
      var reservationGuid = Guid.NewGuid();
      var resourceGuid = Guid.NewGuid();
      var nodeId = 1;
      var reservation = SrmManagers.ResourceManager.GetReservationInstance(reservationGuid);
      var bookingManager = reservation.FindBookingManager();
      bookingManager.TryRemoveResourceAndNode(engine, ref reservation, resourceGuid, nodeId);
      // Example of passing a service definition template as an extra parameter to the TryRemoveResourceAndNode method
      var existingServiceDefinitionGuid = Guid.NewGuid();
      bookingManager.TryRemoveResourceAndNode(engine, ref reservation, resourceGuid, nodeId, existingServiceDefinitionGuid);
  • In case a service definition needs to be created, it will not be a template.
  • A non-template service definition will not be cleaned up.
  • From SRM 1.2.33 onwards, it is possible to pass the desired service definition as a parameter to the RemoveResourceAndNode and TryRemoveResourceAndNode methods. If the passed service definition contains the correct nodes, it will be used; otherwise the behavior will be the same as described above.
