Silently updating the timing of a booking
The example below shows how the timing of a booking can be changed without user interaction by means of an automation script.
  • The timing of events that have already been executed cannot be changed.
  • Dates should be passed in local time. The Booking Manager will take care of converting them to UTC.
using System;
using Skyline.DataMiner.Core.SRM;
using Skyline.DataMiner.Core.SRM.Extensions.Reservations;
using Skyline.DataMiner.Core.SRM.Model.ReservationAction;
public class Script
   public static void Run(Engine engine)
      // Replace with reservation guid
      var reservationId = Guid.NewGuid();
      // Replace with expected timing
      var start = DateTime.Now.AddHours(2);
      var end = start.AddHours(4);
      var preRoll = TimeSpan.FromMinutes(5);
      var postRoll = TimeSpan.FromMinutes(5);
      var reservation = SrmManagers.ResourceManager.GetReservationInstance(reservationId);
      var bookingManager = reservation.FindBookingManager();
      var newTiming = new ChangeTimeInputData
         StartDate = start,
         EndDate = end,
         PreRoll = preRoll,
         PostRoll = postRoll,
         IsSilent = true,
      var result = bookingManager.TryChangeTime(engine, ref reservation, newTiming);
From version 2.0.2 of the SRM framework feature release track (Dev Pack) onwards, it is possible to finish a permanent booking while defining a post-roll time. To do so, change the timing of that booking using ChangeTime/TryChangeTime like in the example above, by changing the end date to a time in the near future and setting the appropriate post-roll time. Providing a post-roll time is not supported when a permanent booking is finished using Finish/TryFinish. Although the timing of contributing bookings will be adapted accordingly if appropriate, no post-roll time will be set for the contributing bookings. In case orchestration is required, you will need to change the timing for each of them separately.
