Alarm level IDs for use in automation scripts
In DataMiner Automation, it can sometimes be necessary to refer to an alarm level by using its ID. The following table lists the IDs for all alarm levels.
ID Status
1 Critical
2 Major
3 Minor
4 Warning
5 Normal
6 High
7 Low
8 Escalated
9 Dropped
10 New Alarm
11 Cleared
12 Open
13 Information
14 Mobile Gateway
15 Service Monitor
16 DataMiner System
17 Timeout
18 Not Assigned
19 Acknowledged
20 Resolved
21 Unresolved
22 Comment Added
23 Correlation Engine
24 Error
25 Mask
26 Automation Engine
27 Unmask
28 Notice
29 WatchDog
30 External
31 Dropped from Critical
32 Dropped from Major
33 Dropped from Minor
34 Dropped from Warning
35 Escalated from Warning
36 Escalated from Minor
37 Escalated from Major
38 Flipped
39 Systemdisplay
40 Service impact changed
41 Value changed
42 Name changed
43 RCA-level changed
44 Element
45 Service
46 View
47 Read-only
48 Read-write
49 Alarm
50 Properties changed
51 Protocol
52 Internal
53 Threshold changed
54 Clearable
