Assign dummy
Use this action to assign an automation script’s dummy to a specific element by using a variable or a value. This can for example be used to allow a script to swap the originally assigned dummy with a different one in case a problem with the dummy is encountered.
  1. Click the left-most underlined field to select or create a dummy element.
    For more information on creating dummy elements, see Creating a dummy.
  2. Select how the new element will be determined:
    • For a pre-determined element, select Value to select a specific element, and enter the element name or ID.
    • For an element determined by a script variable, select Variable and select the variable.
    The value of the variable or the directly specified value should contain either the dmaID and elementID formatted as “dmaID/elementID” or the element name.
