Assign template
Use this action to assign an alarm or trend template to a dummy:
  1. To assign a trend template, click the default Alarm template option, and select Trend template instead.
  2. Next to for, click the underlined field to either add an existing dummy element or create a new dummy element.
    For more information on creating dummy elements, see Creating a dummy.
  3. To select a variable, click the default Value option, and select Variable instead.
  4. Click the final underlined field and select a script variable or, if you chose Value, an existing template.
