Find interactive client
Use this action to ask an interactive user to attach to the script. In a message box, the user will be asked to choose between the following two options:
  • Attach: the script will start in a pop-up window.
  • Ignore: the message box will be closed.
Both if the user accepts or ignores the request, an information event will be generated.
To configure the action:
  • Next to Show message, click the underlined field to add the message that will appear in the message box.
  • Next to Timeout, specify how long the script should wait for the user to react. When this timeout expires, the script will continue and the FindInteractiveClient method returns "False".
  • If, as an interactive client, you manually execute a script from DataMiner Cube, you are automatically attached.
  • It is also possible to add this action within a C# block in a script. For more information, see FindInteractiveClient.
  • If an interactive script is launched, but it cannot be executed because an element or memory file is locked, a message will inform the user of which element or memory file is locked, and by whom.
