Manually executing a script
If you want to manually execute an automation script, do the following:
  1. In DataMiner Cube, go to Apps > Automation.
  2. In the list on the left side of the Automation card, select the script to be executed.
  3. Click the Execute button at the bottom of the pane on the right.
  4. Specify the required dummies, parameters and memory files, and select or deselect the available options if necessary. For an overview of the options, see Script execution options.
  5. Click Execute now to start the script.
If for any reason you want to cancel running the script, just click Close instead.
