Special parameters available in automation scripts
In an automation script, a number of special parameters allow you to access information about users, redundancy states, and correlation information.
The following table lists the special parameters available in automation scripts.
Name ID Description
<User Description> 65000 The displayed name of the user (only if the script was executed manually by a particular user).
<User Name> 65001 The logon name of the user (only if the script was executed manually by a particular user).
<Redundancy Type> 65003 The type of redundancy group switch (only if the execution of the script was caused by a redundancy group switch).
Values:
- SWITCH_OVER
- SWITCH_BACK
<Redundancy Cause> 65004 The cause of a redundancy group switch (only if the execution of the script was caused by a redundancy group switch).
Values:
- prioritychanged
- manual
- automatic
<Correlation State> 65002 Whether the correlation rule was triggered because the trigger condition matched the alarm ("up"), the base alarms were updated ("update"), or the trigger condition no longer matched the alarm ("down") (only if the script was executed via a correlation rule).
Values:
- up
- update
- down
<Correlation Alarm ID> 65005 [Obsolete] The ID of the alarm that triggered the correlation rule (only if the script was executed via a correlation rule). Avoid using this value. Extract the full alarm tree reference from <Correlation Alarm Info> (65006) instead.
<Correlation Alarm Info> 65006 A pipe-separated string containing information about the alarm that triggered the correlation rule (only if the script was executed via a correlation rule):
0:alarmId|1:agentId|2:elementId|3:parameterId|4:parameterIdx|5:rootAlarmId|6:previousAlarmId|7:severity|8:type|9:status|10:alarmvalue|11:alarmTime|12:serviceRca|13:elementRca|14:parameterRca|15:severityRange|16:sourceId|17:userStatus|18:owner|19:impactedServices|20:propertyCount|propcount*2|scriptNamevt0:alarmId|1:agentId|2:elementId|3:parameterId|4:parameterIdx|5:rootAlarmId|6:previousAlarmId|7:severity|8:type|9:status|10:alarmvalue|11:alarmTime|12:serviceRca|13:elementRca|14:parameterRca|15:severityRange|16:sourceId|17:userStatus|18:owner|19:impactedServices|20:propertyCount|propcount*2|scriptName
For an example of how to parse the information in this string, see How do I parse Correlation Alarm Info data?
For more information on how to retrieve the value of a parameter in a script, see How do I retrieve the current value of a script parameter?
