Deleting a component
You can delete a component as follows:
  • Click on the component or hover the mouse pointer over the component and click the red recycle bin icon.
  • Select the component and click Delete component in the header bar of the app (only in the Dashboards app).
  • Select the component and press the Delete key (supported from DataMiner 10.2.0/10.1.1 onwards).
