Configuring user settings
From DataMiner 10.4.0 [CU21]/10.5.0 [CU9]/10.5.12 onwards, you can change certain user-specific settings directly from the Low-Code Apps interface. As of now, this allows users with the appropriate user permissions to change their password from within an app, without needing to access Cube.
A user can only access the user settings if the following conditions are met:
In System Center > Users, the user's User cannot change password setting must be disabled.
The user must have the Modules > System configuration > Security > Specific > Limited administrator permission.
The user must not be logged in with external or delegated authentication.
Changing your password
To change your password directly from the Low-Code Apps interface:
Click the user button in the upper-right corner.
Select User settings.
In the User settings pop-up window, enter your old password and then enter your new password twice.
Select Update password to confirm the new password.
