About the Element Connections module
Use the Element Connections module in DataMiner Cube to link parameters in virtual elements to parameters in other elements. This is what makes it possible for a virtual element to combine data from one or more "real" elements. For background information on virtual elements, see Virtual elements.
Element Connections module in DataMiner 10.6.10
For the step-by-step procedure to link parameters, see Configuring virtual elements.
The Element Connections module does not configure DataMiner Connectivity Framework connections between protocol interfaces. To configure those connections, see Configuring element connectivity in Cube.
