Serial connections
For serial connections, you can specify the following connection settings while creating or editing an element:
  • Baud rate: The baudrate specified in the manual of the device, e.g., 9600.
  • Databits: The databits specified in the manual of the device, e.g., 7.
  • Stopbits: The stopbits specified in the manual of the device, e.g., 1.
  • Parity: The parity specified in the manual of the device, e.g., No.
  • Flow control: The flow control specified in the manual of the device, e.g., No.
  • Serial port: The serial port of the DMA that should be used. If only one port is available, it is automatically selected.
