Changing parameter names for a particular element
To change the names of parameters for one particular element.
  1. In the card header menu, select Parameter names.
  2. Enter any custom parameter names in the Custom name column.
  3. Click Apply to apply your changes, or OK to apply the changes and close the Parameter names window.
  • It is not possible to create two parameters with the same name, or two parameters with a very similar name where the only difference is the use of brackets in one of the parameter names. In addition, the following characters are not allowed in parameter names: >, <, &, %.
  • To use custom parameter names for all elements of a particular protocol, use an information template instead. See Information templates.
