Discrete, analog, and hybrid parameters
Discrete parameters
These parameters can have one of a limited set of predefined values. These can for instance be different strings.
Discrete parameter in DataMiner 10.6.5
For more information on how to update discrete parameters, see Updating discrete parameters.
Analog parameters
These parameters can have a value within a predefined range delimited by a minimum and a maximum.
Analog parameter in DataMiner 10.6.5
For more information on how to update analog parameters, see Updating analog parameters.
Hybrid parameters
These parameters are similar to analog parameters, but can have a so-called exceptional, discrete value (e.g., "Not Used").
Hybrid parameter in DataMiner 10.6.5
If this exceptional value is selected, the rest of the parameter control will be shown as unavailable. This way, you can immediately see if a hybrid parameter has been set to its exception value.
For more information on how to update hybrid parameters, see Updating hybrid parameters.
