Changing the parameter layout in Lite mode
To change the parameter layout in Lite mode:
  1. Go to the Data Display page of the user settings. See User settings.
  2. Change the following settings as required:
    • Parameter Title Font: Click the "..." button to select a new parameter title font.
    • Parameter Value Font: Click the "..." button to select a new parameter value font.
    The font of table parameters cannot be adjusted.
    • Parameter Value Alignment: In the dropdown list on the right, choose either Left or Right to align parameter values on the left or on the right. By default, they are aligned on the right.
    • Always show editor controls: Select this setting to always display the write controls for parameters. Otherwise, a pencil icon will be displayed that the user has to click in order to see the write controls.
    • Outer margin/Inner margin: Specify a margin in px, pt, in or cm, in one of the following three formats:
      • [uniform]
      • [horizontal], [vertical]
      • [left], [top], [right], [bottom]
      The default margin is 0 px.
