Using the Lite mode shortcut menu
When you right-click parameters in Lite mode, a different shortcut menu appears than in normal mode.
With the shortcut menu, you can:
  • Copy the value of the parameter.
  • Copy the title and value of the parameter.
  • Copy the DMA ID, Element ID and Parameter ID of the parameter.
  • Go to the parameter details.
    You can also double-click a parameter to go to the parameter details.
