Deleting an alarm template
To delete an existing alarm template for a particular protocol version:
  1. Go to Apps > Protocols & Templates.
  2. Select the protocol in the first column and the protocol version in the second column.
  3. Right-click the alarm template under Alarm in the third column, and select Delete.
If any elements are using the template when you delete it, these will have the template <No Monitoring> assigned to them instead.
