Adding and deleting trend templates
To learn how to create a trend template, you can follow the steps below or watch this short video:
Watch first: Creating a DataMiner element and Creating an alarm template
See also: Trend icons
Creating a trend template
To create a new trend template:
  1. Go to Apps > Protocols & Templates.
  2. Select a protocol in the first column and a protocol version in the second column.
  3. Right-click in the third column under Trend, and select New.
    To create a new trend template that is very similar to one that already exists, it can be handy to duplicate the existing template instead of creating a blank new template. To do so, instead of selecting New, select the template that is similar, and then select Duplicate in the right-click menu.
  4. In the New trend template dialog box:
    1. Enter a template name.
      Some characters cannot be used in template names. For more information, see Naming of elements, services, views, etc..
    2. Check if the protocol and protocol version are correct and adapt if necessary.
    3. Click OK.
    The template editor now opens, where you can further configure the trend template.
Uploading a trend template
To upload a trend template for a particular protocol version:
  2. Select the protocol in the first column and the protocol version in the second column.
  3. Right-click under Trend in the third column, and select Upload.
  4. Browse to the trend template in question and click Open.
    Only files that start with Template_ will be recognized as trend templates.
Deleting a trend template
To delete an existing trend template for a particular protocol version:
  3. Right-click the trend template under Trend in the third column, and select Delete.
