Assigning trend templates
There multiple different ways to assign a trend template.
In the Surveyor:
  1. Right-click the item in the Surveyor.
  2. In the context menu, select Protocols & Templates > Assign trend template, and then select the trend template you want to assign.
  3. In the confirmation box, click Yes.
By editing the item:
  1. Either right-click the item in the Surveyor, or click the hamburger button in the upper-left corner of the item's card, and select Edit.
  2. In the Edit tab, go to the Device Details section.
  3. Select the trend template in the Trend Template selection box.
  4. Click Apply.
In the Protocols & Templates module:
  1. Select the protocol and protocol version
  2. In the Trend section, select the trend template.
  3. Right-click in the Elements section and select Assign Template.
  4. In the Assign template window, use the Add >> and << Remove buttons to assign the template to particular items.
    All items in the column on the right have been assigned this trend template.
  • Right-click an item in the Protocols & Templates module and select Remove to quickly remove a trend template from an item.
  • Assigning templates is also possible via the elements tab of the Protocols & Templates module. See Working with the elements tab.
