Setting a primary or backup element in maintenance
If you want to prevent an element from being switched automatically, you can set it “in maintenance”.
  • Go to the Advanced section of a redundancy group card.
  • Click a Switch to maintenance mode button underneath a primary or backup element to switch that element to maintenance mode.
You can only perform the above-mentioned action if software redundancy has been configured for the redundancy group in question.
