SLAutomation memory leak when automation script runs
Affected versions
DataMiner 10.5.6
Cause
In DataMiner 10.5.6, a new pointer to SLLog is created for every automation script that runs. This causes SLAutomation to leak memory each time an automation script runs.
Fix
Install DataMiner 10.5.7.
Workaround
Restart the DataMiner Agent to cause the memory usage to decrease again. However, note that this is a temporary workaround that will not fix the issue.
Description
In DataMiner Systems using DataMiner 10.5.6, SLAutomation keeps using more memory after each automation script run.
