SLDataGateway issue caused by OpenSearch health monitoring
Affected versions
Dedicated clustered storage setups using DataMiner 10.5.0 [CU11]/10.6.2.
Cause
Because of changes introduced in DataMiner 10.5.0 [CU11]/10.6.2, with certain DB.xml configurations or recent OpenSearch versions, the search database can be stuck in the RED health state and SLDataGateway can crash at startup.
Fix
Install the latest, patched version of DataMiner 10.5.0 [CU11] or DataMiner 10.6.2 [CU1].
Description
After upgrading to DataMiner 10.5.0 [CU11]/10.6.2, SLSearchHealth.txt reports issues with the health monitor, and it can occur that SLDataGateway crashes at startup.
