SRM - Auto Select Resource not read for silent booking
Affected versions
SRM 1.2.30 CU2.
Cause
When a booking was created silently, the Auto Select Resource node property was not read.
Fix
Install SRM 1.2.30 CU3.
Workaround
In the automation script, pass the function with ShouldAutoSelectResource=false.
Description
When a booking was created silently, resources were automatically selected even if the Auto Select Resource node property was set to False.
