System.StackOverflowException
If a connector QAction causes a stack overflow in SLScripting, collect the crash dump and note the connector version.
To locate the failing method in the QAction assembly, refer to Investigating StackOverflowException occurrences. Check for recursion without a terminating condition and correct the connector code if found.
A stack overflow can terminate SLScripting before it writes a log entry. If the dump does not show a stack overflow, use the SLScripting troubleshooting procedures.
