General Feature Release 10.2.12 CU1 [ARCHIVED]
Fixes
Low-Code Apps: Dropdown box containing an 'execute component' action would incorrectly be empty [ID 34953]
When an execute component action had been configured, in some cases, when you tried to update that action, the dropdown box containing the action would incorrectly be empty.
Dashboards app & low-Code Apps: Manually sorted GQI table would no longer feed row values [ID 34969]
When you had manually changed the sorting order of a GQI table by clicking a column header, in some cases, the table would no longer feed the selected row values.
