General Feature Release 10.3.10 CU1
When downgrading from DataMiner Feature Release version 10.3.8 (or higher) to DataMiner Feature Release version 10.3.4, 10.3.5, 10.3.6 or 10.3.7, an extra manual step has to be performed. For more information, see Downgrading a DMS.
Changes
Enhancements
STaaS: Enhanced performance when sending data to the cloud [ID 37141]
Because of a number of enhancements, overall performance has increased when sending data to the cloud.
Fixes
Problem when migrating average trend data from Cassandra Cluster to STaaS [ID 37410]
When migrating data from a Cassandra Cluster setup to STaaS, average trend data would be migrated incorrectly.
STaaS: Problem when assigning/removing an alarm template to/from a DVE child element [ID 37443]
On systems with Storage as a Service, the data would not get saved correctly when you assigned an alarm template to a DVE child element or when you removed an alarm template from a DVE child element.
