General Feature Release 10.4.3
When downgrading from DataMiner Feature Release version 10.3.8 (or higher) to DataMiner Feature Release version 10.3.4, 10.3.5, 10.3.6 or 10.3.7, an extra manual step has to be performed. For more information, see Downgrading a DMS.
Highlights
DataMiner requirements: .NET 8.0 now required [ID 37969]
To be able to upgrade to DataMiner 10.4.3, you will first need to install the Microsoft ASP.NET 8.0 Hosting Bundle.
If this requirement is not met, a new prerequisite check during the upgrade will notify you that you will first need to take care of this before you can install the upgrade.
Breaking changes
Microsoft Entra ID: Enhanced user and group import [ID 38154]
A number of improvements have been made with regard to importing users and user groups into Microsoft Entra ID (formerly known as Azure Active Directory):
  • Enhanced performance for tenants with large amounts of users and groups.
  • Support for users of which the name contains non-ASCII characters, users sharing the same given name and surname, and users of whom the given name and/or surname is not provisioned.
  • Group descriptions will now also be imported.
These improvements include the following breaking change:
User name format has changed from {organization}\{givenName}.{surname} to {domain}\{username} based on the userPrincipalName.
This format is now consistent with automatic user provisioning via SAML authentication.
For example, "ZIINE\Björn.Waldegård" with userPrincipalName bjorn.waldegard@ziine.com will now become "ziine.com\bjorn.waldegard".
If you are using SAML with Microsoft Entra ID and you have imported single users from Entra ID (indicated with a blue icon in the Users/Groups module in Cube), take the following steps when you upgrade:
  1. Make sure a local admin user can be used on the server.
    If no such user exists yet, create one.
  2. Take a backup of the C:\Skyline DataMiner\Users folder and of the file C:\Skyline DataMiner\Security.xml.
  3. Upgrade DataMiner.
  4. Log in with the local admin user, and replace the imported users:
    1. Add the new users.
    2. Place them in the same security group.
    3. Remove the old imported users.
    4. If you want to restore the client settings for the users, copy the user files from the backup you created earlier and add them to the relevant folders under C:\Skyline DataMiner\Users.
  5. If the users were able to use dataminer.services features, you will need to remove their old account in the Admin app and then add the new account. See Controlling user access to dataminer.services features.
NATS: All processes will now use the DataMinerMessageBroker.API NuGet package [ID 38193]
All processes that were still using the deprecated SLMessageBroker.dll or CSLCloudBridge.dll files will now be using the DataMinerMessageBroker.API or DataMinerMessageBroker.API.Native NuGet package instead.
Processing using ... will now instead use ...
SLMessageBroker.dll DataMinerMessageBroker.API
CSLCloudBridge.dll DataMinerMessageBroker.API.Native
This is a breaking change. It will cause the VerifyNatsIsRunning prerequisite to fail when you downgrade to an earlier DataMiner version, because this prerequisite will expect the old SLMessageBroker DLL instead of the DataMinerMessageBroker API. To be able to downgrade, you will need to open the upgrade package you want to downgrade to (like a zip archive) and remove VerifyNatsIsRunning.dll from the \Update.zip\Prerequisites\ folder.
New features
SLNetClientTest tool: New SLProtocol health statistics [ID 37617]
When, in the SLNetClientTest tool, you open the Diagnostics > DMA menu, you can now find the following new commands:
Command Function
Health Stats (SLProtocol) > Stats Show the overall SLProtocol memory used by all elements.
Health Stats (SLProtocol) > Details... Show all details of a specific element.
DataMiner Maps: ForeignKeyRelationsSourceInfo tag now supports an elementVar attribute [ID 38274]
In a <ForeignKeyRelationsSourceInfo> tag, it is now possible to specify an elementVar attribute.
<ForeignKeyRelationsSourceInfo elementVar="myElement">
</ForeignKeyRelationsSourceInfo>
This will allow you to pass an element in the map's URL. See the URL examples below (notice the “d” in front of the parameter name!):
maps.aspx?config=MyConfigFile&dmyElement=7/46840
maps.aspx?config=MyConfigFile&dmyElement=VesselData
DataMiner Object Models: New 'GetDifferences' method to compare two DOM instances [ID 38364]
The DomInstanceCrudMeta input object of a DOM CRUD script has a new GetDifferences method that allows you to see the changes made to a DOM instance. It will compare the previousVersion and the currentVersion of the instance in question, and return the list of differences found.
Changes
Enhancements
SLAnalytics - Alarm focus: Alarm occurrences will now be identified using a combination of element ID, parameter ID and primary key [ID 38184] [ID 38251]
When calculating alarm likelihood (i.e., focus score), up to now, the alarm focus feature used a combination of element ID, parameter ID and display key (if applicable) to identify previous occurrences of the same alarm. From now on, previous alarm occurrences will be identified using a combination of element ID, parameter ID and primary key.
When you upgrade to version 10.4.0/10.4.3, the Cassandra table analytics_alarmfocus will automatically be removed.
SLNetClientTest tool: Message builder now allows creating an instance of an abstract type or interface [ID 38236]
The message builder in the SLNetClientTest tool allows you to build SLNet messages from scratch, filling out values for the properties in DMSMessage objects.
Up to now, if these properties were for an abstract type or interface, it was not possible to fill out a value. From now on, it will be possible to select a concrete type, create an instance, and edit the properties of that object.
DataMiner Object Models: Required list fields can no longer be set to an empty list [ID 38238]
From now on, when the value of a required list field is set to an empty list, one of the following errors will be thrown:
  • DomInstanceHasMissingRequiredFieldsForCurrentStatus (when using the DOM status system)
  • DomInstanceDoesNotContainAllRequiredFieldsForSectionDefinition (when not using the DOM status system)
DataMiner Object Models: HistoryChanges will now be processed in bulk [ID 38241]
Up to now, if history storage was enabled, when DomInstances were created, updated or deleted, a HistoryChange operation would be executed for every DomInstance separately.
From now on, for every batch of DomInstances that are processed in bulk, the history records will also be processed in bulk.
Security enhancements [ID 38263] [ID 38386] [ID 38514]
Failover: NATS nodes will now advertise their physical IP address instead of their virtual IP address [ID 38340]
From now, NATS nodes will advertise their physical IP address instead of their virtual IP address.
SLAnalytics: Cassandra tables 'analytics_parameterinfo_v1' and 'analytics_wavestream' will be dropped when downgrading [ID 38336]
When downgrading a DataMiner System using a Cassandra database, from now on, the Cassandra tables analytics_parameterinfo_v1 and analytics_wavestream will be dropped. Contrary to the old versions, the new versions no longer contain display keys.
SLAnalytics - Behavioral anomaly detection: Enhanced accuracy [ID 38383]
The accuracy of the behavioral change points and anomalies detected by the behavioral anomaly detection feature has been improved.
From now on, a behavioral change will only be taken into account when the change is larger than the data precision used to display the data in DataMiner Cube.
As a result, anomalies that report a trend change "from 0%/day to 0%/day", a level shift from "0.1 to 0.1", etc. will no longer be taken into account.
SLProtocol will now always fetch element data page by page except on systems with a MySQL database [ID 38388]
From now on, SLProtocol will always fetch element data page by page, except on systems with a MySQL database.
On systems with a MySQL database, SLProtocol will continue to fetch element data by parameter ID.
When SLProtocol identifies duplicate keys, it will no longer flood the error log with messages related to duplicate keys (e.g., Duplicate key in table 1000, key = 123) at the default log levels.
From now on, if you want to have log entries related to duplicate keys, increase the error log level to 1.
When polling via SNMP, duplicate keys will only be logged when error log level is set to 1. When using FillArray in a QAction, duplicate keys will always be logged regardless of error log level.
DataMiner upgrade: SLAnalytics upgrade actions now support Cassandra connections with TLS [ID 38393]
DataMiner upgrade actions related to SLAnalytics features now also support Cassandra connections with TLS.
User-Defined APIs: Maximum size of HTTP response body has been reduced to 29MB [ID 38397]
As of version 10.4.1, the maximum size of the HTTP request body is 29 MB. Now, also the maximum size of the HTTP response body has been reduced to 29 MB.
SLAnalytics - Behavioral anomaly detection: Enhanced accuracy [ID 38400]
Change point detection accuracy has been improved for parameters that have a discreet trend data behavior.
For parameters of which the trend data behavior is mostly stable, with only infrequent sudden value changes, only behavioral changes that are larger than those infrequent sudden value changes will be taken into account.
SLAnalytics: Trend data pattern records will no longer be deleted from the database [ID 38407]
From now on, trend data pattern records will no longer be deleted from the Elasticsearch/OpenSearch database.
Enhanced performance when updating cell-based subscriptions in SLNet [ID 38445]
Because of a number of enhancements, overall performance has increased when updating cell-based subscriptions in SLNet.
These subscriptions mostly originate from visual overviews.
GQI: Enhanced performance when executing 'Get parameters from elements' queries for parameter tables [ID 38460]
When a Get parameters from elements query is executed for a parameter table, from now on, the table sessions that are used to resolve those tables in parallel will be closed asynchronously.
As a result, overall performance of clients like the Dashboards app or a low-code app will significantly increase when executing this type of queries.
SLAnalytics: Enhanced memory usage [ID 38471]
Because of a number of enhancements with regard to memory usage, overall performance of SLAnalytics has increased.
User-Defined APIs: Enhanced logging [ID 38491]
Up to now, when a user-defined API was triggered, log entries like the ones below would only be added to the SLUserDefinableApiManager.txt file when the log level was set to 5. From now on, when a user-defined API is triggered, these entries will be added to SLUserDefinableApiManager.txt when the log level is set to 0 (i.e., always).
2024/01/18 10:13:00.740|SLNet.exe|Handle|CRU|0|152|[1f9cd6c045] Started handling API trigger from NATS for route 'dma/id-2'.
2024/01/18 10:13:01.268|SLNet.exe|Handle|CRU|0|152|[1f9cd6c045] Handling API trigger from NATS for route 'dma/id-2' SUCCEEDED after 526.46 ms. API script provided response code: 200. (Token ID: 78dd7916-6d01-4c17-9010-530c28338120)
DxMs upgraded [ID 38499] [ID 38596]
The following DataMiner Extension Modules (DxMs), which are included in the DataMiner upgrade package, have been upgraded to the indicated versions:
  • DataMiner ArtifactDeployer: version 1.6.4.14010
  • DataMiner CoreGateway: version 2.14.3
  • DataMiner FieldControl: version 2.10.3.14011
  • DataMiner Orchestrator: version 1.5.3.14012
  • DataMiner SupportAssistant: version 1.6.4.14013
For detailed information about the changes included in those versions, refer to the DxM release notes.
SLAnalytics - Proactive cap detection: Enhanced accuracy [ID 38508]
The accuracy of proactive cap detection events (i.e., forecasted alarms) reporting data range violations has been improved.
Service & Resource Management: Enhanced performance when adding or updating bookings [ID 38521]
Because of a number of enhancements, overall performance has increased when adding or updating bookings, especially on systems with a large number of bookings.
MessageBroker: Clients will now throw a DataMinerMessageBrokerException when a single NATS node is stopped while they are busy writing data [ID 38523]
When a single NATS node was stopped because it needed to be reconfigured, up to now, clients that were busy writing data would throw a NotSupportedException. From now on, they will throw a DataMinerMessageBrokerException instead.
SLAnalytics - Behavioral anomaly detection: Enhanced detection of change points of type flatline [ID 38528]
Change point detection accuracy has been improved for change points of type flatline.
DataMinerSolutions.dll now included in core DataMiner software [ID 38530]
To make sure that installing IDP will no longer require a DataMiner restart, DataMinerSolutions.dll will now be included in the core DataMiner software.
SLAnalytics: Notification alarm 'Failed to start Analytics feature(s)...' will now be cleared automatically [ID 38621]
The following notification alarm, generated when an SLAnalytics feature failed to start up, will now be automatically cleared when that same feature starts up correctly.
Failed to start x Analytics feature(s). Check the Analytics logging (SLAnalytics.txt) for more information.
Fixes
DataMiner installer: Some modules would not get installed while performing a full installation of a new DMA [ID 37719]
Up to now, when you ran the DataMiner installer to install a new DataMiner Agent using a DataMiner upgrade package, some modules would incorrectly not get installed as they were configured to only be installed when upgrading an existing DataMiner Agent.
From now on, when you run the DataMiner installer to install a new DataMiner Agent using a DataMiner upgrade package, all installation steps will be performed, including the upgrade actions.
Web apps: Visual overview linked to a view would not get any updates when the user did not have full administrative rights [ID 38180]
When a web app user without full administrative rights viewed a visual overview linked to a view, the app would incorrectly not receive any updates for that visual overview.
DataMiner clients using a gRPC connection would not always detect a disconnect [ID 38215]
In some cases, DataMiner clients using a gRPC connection would not detect a disconnect.
DataMiner Cube was not able to reconnect to the server after a disconnect using gRPC [ID 38260]
Up to now, when using a gRPC connection, Cube was not able to verify whether the server endpoint was available. As a result, it would fail to reconnect to the server when the connection had been lost and would display a Waiting for the connection to become available... message indefinitely.
Web apps - Visual overview: Popup window would not display a hidden page when the visual overview only contained one non-hidden page [ID 38331]
When, in a visual overview with one non-hidden page displayed in a web app, you tried to open a popup window linked to a page marked as "hidden", the popup window would incorrectly display the non-hidden page instead of the hidden page.
Automation: Script data cleanup routine could cause an error to occur [ID 38370]
In some rare cases, a cleanup routine within SLAutomation could prematurely clean up data of scripts that had not yet finished, causing an error to occur.
Automation: Problem when empty data is passed to the UI parser when running an interactive automation script [ID 38408]
When running an interactive automation script that was launched from Cube or a web app, in some cases, an exception could be thrown when empty data was passed to the UI parser.
From now on, an exception will no longer be thrown when empty data is passed to the UI parser.
DataMiner upgrade: Problem with AnalyticsParameterInfoRecordAddChangeRate upgrade action on systems with a Cassandra Cluster database [ID 38443]
During a DataMiner upgrade, the AnalyticsParameterInfoRecordAddChangeRate upgrade action executes an Alter Table command on every DataMiner Agent in the cluster. Up to now, when you upgraded a DataMiner System with a Cassandra Cluster database, that Alter Table command would incorrectly only get executed on the first DMA that called it. On each subsequent DMA that called the command, errors would get thrown and added to the upgrade.log file.
Problem with SLDMS [ID 38469]
In some cases, an error could occur in the SLDMS process when the SLDMKey object was accesses from multiple threads.
DataMiner Cube was not able to reconnect to the server after a disconnect [ID 38481]
In some cases, DataMiner Cube would not be able to reconnect to the server after having been disconnected.
Fatal error reported in Windows Event Viewer each time the APIGateway was stopped [ID 38504]
Each time the APIGateway service was stopped, a fatal error would incorrectly be reported in the Windows Event Viewer.
Alarm filters would not be properly serialized when using a gRPC connection [ID 38507]
When a client application was connected to a DataMiner Agent via a gRPC connection, in some cases, the alarm filters it received from the DataMiner Agent would not be properly serialized.
SLAnalytics - Behavioral anomaly detection: Certain parameter value changes would incorrectly not get processed [ID 38545]
When SLAnalytics was handling large amounts of traffic, in some cases, certain parameter value changes would incorrectly not get processed.
Also, a large number of low-severity change points were generated without a label. Those have now been reduced.
SLAnalytics - Pattern matching: A match of one subpattern would incorrectly be considered a match of the entire multivariate pattern [ID 38587]
When the streaming method was being used, a match detected for one subpattern of a multivariate pattern would incorrectly be considered a match of that entire multivariate pattern.
Although the suggestion events were generated correctly, the pattern matches would not be indicated correctly on the trend graphs.
SLAnalytics features would not start up correctly after a database connection problem [ID 38600]
Up to now, when writing to the database or reading from the database failed, a retry was attempted after 5 seconds. In some cases, especially when the SLNet connection was lost during startup, that retry would also fail, causing certain SLAnalytics features to not start up correctly. From now on, when writing to the database or reading from the database fails, SLAnalytics will wait longer than 5 seconds before attempting a retry.
Protocols: IDisposable QActions would incorrectly not be disposed [ID 38605]
When DataMiner was processing all QActions in order to call the Dispose method on the QActions that implement IDisposable, it would incorrectly no longer call the Dispose method on QActions that implement IDisposable after processing a QAction that did not implement IDisposable.
Problem when adding a DMA to a DMS [ID 38620]
When a DataMiner Agent was added to a DataMiner System, in some cases, the SLNet cache of the new DataMiner Agent would not get updated, causing the Agent to not be aware it was now part of a DMS.
Problem with SLDataMiner while sending a SetDocumentEofMessage with a negative file number [ID 38712]
In some cases, SLDataMiner could stop working while sending a SetDocumentEofMessage with a negative file number via SLNet.
