General Feature Release 10.5.2 CU1
Before you upgrade to this DataMiner version, make sure version 14.40.33816 or higher of the Microsoft Visual C++ x86/x64 redistributables is installed. Otherwise, the upgrade will trigger an automatic reboot of the DMA in order to complete the installation.
The latest version of the redistributables can be downloaded from the Microsoft website:
Changes
Fixes
Problem when upgrading to DataMiner 10.5.1 or 10.5.2 [ID 42058]
When a DataMiner Agent was upgraded to DataMiner feature version 10.5.1 or 10.5.2, the upgrade would get stuck when users in the Security.xml file had expired set to "true".
