General Feature Release 10.5.7 CU1
Before you upgrade to this DataMiner version, make sure version 14.40.33816 or higher of the Microsoft Visual C++ x86/x64 redistributables is installed. Otherwise, the upgrade will trigger an automatic reboot of the DMA in order to complete the installation.
The latest version of the redistributables can be downloaded from the Microsoft website:
Changes
Fixes
SLNet memory leak caused by ClusterEndpoint.json sync [ID 43407]
In large DataMiner Systems, especially in clusters with Failover Agents, an issue could occur when the ClusterEndpoints.json files were being synchronized, causing the DataMiner Agents to keep on synchronizing those files indefinitely. This could lead to a serious memory leak in SLNet, causing DataMiner Agents to disconnect frequently.
