Deleting a maintenance event
To permanently delete a PLM item from the system, follow these steps:
  1. On the PLM Instances page, select the maintenance event you want to delete.
  2. Click Delete in the upper-left corner of the header bar.
  3. In the pop-up window, review the information and confirm that you want to delete this item by clicking OK.
    The PLM item will now be deleted from the PLM overview.
