Editing a maintenance event
To edit a maintenance event in the PLM tool, follow these steps:
  1. Go to the PLM Instances page and select the maintenance event you wish to edit.
  2. Click Edit in the upper-left corner of the header bar.
  3. In the pop-up window, adjust the settings you wish to modify.
  4. To apply all changes, select OK.
    The updated details are now visible in the PLM overview.
