Monitoring Processed Traps
Once at least one trap processor element has been configured to process traps from a valid source that is actively generating events, you can monitor the processed events and heartbeats on the Processed Traps page of the Smart Trap Processor tool.
Smart Trap Processor home page
  • At the top, you can find the total number of trap processors available for monitoring.
  • Each available trap processor element is displayed in a grid view. You can select an element in the grid to filter the data below the grid so that only information for that processor element is shown.
  • Each element block in the grid shows the element name, state, current alarm status, trap IP sources, maximum age of events, Keep Alive setting, protocol name, and protocol version.
  • When an element is selected, the following information is shown above the Processed Traps table:
    • The number of active events in the Processed Traps table.
    • The number of cleared events in the Processed Traps table.
    • The number of events matching various alarm severities: Critical, Major, Minor, Warning.
  • When an element is selected, you will find the following information in the Processed Traps table:
    • Alarm Description: Values corresponding to the Alarm Set and Alarm Clear parameters in the Rules table.
    • Event State: This can be Active or Cleared, depending on whether the last processed trap for the row matched the Set or Clear OID defined in the Rules table.
    • Timestamp: The time when the last event was processed for a row.
    • Trap Count: The total number of traps that have been processed for a row.
    • Source IP: The IP address from which the trap events originated.
    • Source IP Name: The name specified for the IP source in the Source IP Name table.
    • Source Name: The name specified for the event source in the Source Name table.
    • Unique Entry: The unique entry value specified in the Rules table.
    Active events are shown at the top of the table. Aside from this, the events are sorted by descending timestamp.
  • When an element is selected, you will find the following information in the Heartbeat Traps table:
    • Heartbeat Status: Can be FAIL or OK, depending on whether the time since the last heartbeat exceeds the expected interval set in the Rules table.
    • Time Since Last Heartbeat: The time since the last heartbeat, calculated by comparing the current time with the timestamp for the last processed heartbeat trap for a row.
    • Heartbeat Interval: The expected interval of heartbeats from a source as defined in the Rules table.
