Remote PHY Monitoring components
System connectors
At the moment only one system connector is supported and required:
Automation scripts
The Remote PHY Monitoring Solution uses the following automation script:
  • CreateVecimaRpmElement: This automation script is responsible for creating a Vecima RPM element on the first deployment or when there is no Vecima RPM element in the system.
Low-code apps
The Remote PHY Monitoring Solution includes the following low-code apps:
  • R-PHY Monitoring: This low-code app allows you to easily monitor all Remote PHY nodes in the system.
  • R-PHY Analog & RF: This low-code app monitors the analog and RF KPIs for all the Remote PHY nodes in the system. This allows on-site technicians to have remote visibility on how the Vecima R-PHY nodes are performing during on-site installation or troubleshooting.
All elements related to the low-code apps (i.e., the Vecima RPM elements) must use the Production version of the connector.
