Installing the Grass Valley AMPP Manager Application
  • DataMiner 10.6.0/10.6.3 or higher
  • A DataMiner System connected to dataminer.services
  • .NET 8.0 (the latest Hosting Bundle under ASP.NET Core Runtime from dotnet.microsoft.com)
    This must be installed on the DataMiner Agent where you will deploy the app. If you are running DataMiner 10.4.10 or higher, this should already be installed, as this is also a requirement for recent DataMiner versions.
  • A connection to an AMPP tenancy via its URL (e.g., https://mytenancy.gvampp.com)
  • An AMPP Control API key generated using the AMPP Identity Manager.
    Starting from version 1.1.8, the installed AMPP Manager connector can also report subscriptions and billing information. To enable these features, you need an additional application client API key of type subscriptions.admin, with the cluster.admin role and allowed scopes for cluster platform. For detailed setup instructions, refer to the AMPP documentation hub.
Deploying the Grass Valley AMPP Manager app
  1. Look up the GV AMPP Manager Application package in the Catalog.
  2. Click the Deploy button.
  3. Select the target DataMiner System and confirm the deployment. The package will be pushed to the DataMiner System.
The Grass Valley AMPP Manager Application package includes:
  • The Grass Valley AMPP Manager connector
  • The GV AMPP Manager low-code app
  • The AMPP automation script folder, which includes scripts used in the app to gather data and perform workload and snapshot control operations
  • The SignalR Forwarder application, which is a .NET Core ASP API application that utilizes Microsoft SignalR libraries for communication with AMPP. It forwards notifications to a listener in a DataMiner element via the GV AMPP Manager connector. Typically, this application is installed on the same DataMiner Agent as the GVAMPP Manager element. It is usually hosted in IIS.
Installing and configuring the communication component
The Grass Valley AMPP Manager app relies on an external component to communicate with the designated AMPP tenancy. This component must be installed and configured on each DataMiner Agent where an AMPP Manager element will be created.
An automation script included in the package helps with both the installation of this component and the creation of the AMPP Manager element. To run the script:
  1. Go to the DataMiner landing page (https://[DMA]/root/).
  2. Open the GV AMPP Manager app.
  3. In the app, click the cogwheel cogwheel icon in the sidebar to open the Setup page.
    This page provides initial instructions and a link to download and install the Microsoft .NET 8.0 Hosting Bundle, in case this is not installed yet.
  4. Click the Configure button to launch the configuration script.
    AMPP Setup Script
  5. In the Dialog window, provide the following information:
    • GVAMPP Endpoint: The URL of the target AMPP tenancy, e.g., https://mytenancy.gvampp.com.
    • API Key: The key generated using the Identity Manager.
    • DMA: For a DMS, select the Agent where the component should be installed and configured.
If the target Agent already hosts an AMPP Manager element, the script will recognize this and avoid any further configuration.
