Standard xPON EPM ONT JSON definition
To be able to use the Kafka data stream properly in the EPM xPON Solution, make sure your data is parsed in the following JSON format:
    "doNotPublish": false,
    "host": {
        "name": "SERVER_NAME"
    "entityId": "00000000-0000-0000-0000-000000000000",
    "oui": "OUI_ID",
    "serial": "ONT_SERIAL_NUMBER",
    "productClass": "ONT_MODEL",
    "deviceModelId": "00000000-0000-0000-0000-000000000000",
    "id": "UNIQUE_ONT_IDENTIFIER",
    "noOfParams": 15,
    "params": {
        "InternetGatewayDevice.DeviceInfo.UpTime": "1126066",
        "InternetGatewayDevice.DeviceInfo.Manufacturer": "VENDOR",
        "InternetGatewayDevice.DeviceInfo.HardwareVersion": "HARDWARE REVISION",
        "InternetGatewayDevice.WANDevice{i}WANPONInterfaceConfig.RXPower": "-20.86",
        "InternetGatewayDevice.WANDevice{i}WANPONInterfaceConfig.TransceiverTemperature": "54.97",
        "InternetGatewayDevice.WANDevice{i}WANPONInterfaceConfig.SupplyVoltage": "3.21",
        "InternetGatewayDevice.WANDevice{i}WANPONInterfaceConfig.TXPower": "2.51",
        "InternetGatewayDevice.WANDevice{i}GponInterfaceConfig.Status": "Up",
        "InternetGatewayDevice.DeviceInfo.Description": "DESCRIPTION TEXT",
        "InternetGatewayDevice.DeviceInfo.SerialNumber": "ONT_SERIAL_NUMBER",
        "InternetGatewayDevice.DeviceInfo.MemUsed": "31",
        "InternetGatewayDevice.WANDevice{i}WANPONInterfaceConfig.BiasCurrent": "14700",
        "InternetGatewayDevice.DeviceInfo.CpuUsed": "3%;2%",
        "InternetGatewayDevice.DeviceInfo.ModelName": "ONT_MODEL",
        "InternetGatewayDevice.DeviceInfo.SoftwareVersion": "SOFTWARE VERSION"
    "@timestamp": "2023-07-06T01:01:39.362Z"
The naming structure for the total parameters follows the TR-069 protocol defined by the Broadband Forum. You can find the complete structure here: TR-069 Full Model.
Field details
Field Name Description Required
host.name Includes the server name, to identify the server sending the data. Yes
entityId Unique identifier for this ONT in the ACS or third-party application No
oui The ID of the OUI. This should be defined by the ACS or the vendor. Yes
serial ONT serial number as reported by the vendor. This will be used as the index to associate the ONT to ports and OLTs. Yes
productClass The ONT model as defined by the vendor. Yes
deviceModelId Unique identifier for this ONT model in the ACS or third-party application. No
id Unique ONT identifier. This should not be repeated in the system per ONT. Yes
noOfParams Total count of reported parameters. Yes
params All reported parameters should be listed here. All names must be aligned with the Broadband Forum and TR-069 Full Model. Yes
@timestamp The timestamp indicating when the file was created. Yes
If you need to monitor any other parameter not listed in this example, contact the Skyline Sales team or your Technical Account Manager to evaluate your options.
