EPM VSAT metrics
The metrics provided below are given as a guide to help dimension EPM VSAT deployments.
All specifications are provided based on the assumption that DMAs are running on servers that comply with the DataMiner compute requirements and the recommended data storage options.
Limits
The limits provided below override any similar, general DataMiner limits under the scope of the EPM VSAT Solution.
# Specification Scope Metric Remarks
1 Number of VSAT remotes DMA 5,000
2 Number of trended parameters VSAT Remote 20
3 Performance parameters polling rate Element 5 minutes When the data point resolution is lower than the polling rate, DataMiner will perform history sets to ensure all data is properly retrieved.
4 Performance parameters data point resolution VSAT Remote 20 seconds
