Cleaning up unused files on a DMA
In System Center, you can clean up unused protocols, unused alarm filters and unused Visio files.
To do so:
In Cube, go to Apps > System Center.
In the System Center module, select the Tools page.
In the second column, select Clean up unused.
Depending on the type of file you want to clean up, do the following:
To clean up unused protocols:
At the bottom of the Protocols tab, click the Load button.
A list with the unused protocols in the DMS will be loaded.
Select the protocols you want to delete and click the Delete button.
To clean up unused alarm filters:
At the bottom of the Alarm filters tab, click the Load button.
A list with the unused alarm filters in the DMS will be loaded.
Select the alarm filters you want to delete and click the Delete button.
The scan for unused alarm filters does not include the usage of alarm filters in the Alarm Console, in DMS dashboards or for alarm blinking. To be sure alarm filters are not used in these applications, a manual check is required.
To clean up unused Visio files:
At the bottom of the Visio files tab, click the Load button.
A list with the unused Visio files in the DMS will be loaded.
Select the files you want to delete and click the Delete button.
