Starting or stopping a DMA in DataMiner Cube
Go to Apps > System Center > Agents.
In the Manage tab, select the DataMiner Agent you want to (re)start or stop, and click one of the following buttons in the pane on the right:
Button Description Stop Stops the DataMiner software on the selected DataMiner Agent. (Re)start Starts or restarts the DataMiner software on the selected DataMiner Agent. Shutdown Shuts down the server hosting the selected DataMiner Agent. Reboot Restarts the operating system of the server hosting the selected DataMiner Agent.
- If you shut down a DMA, you will not be able to start it again by remote control. Someone will have to go where the server is located and start it manually.
- On DataMiner Agents running recent Windows operating systems, the startup type of the DataMiner services is set to "Automatic (Delayed Start)" by default. This means that DataMiner waits until all Windows services are up and running before launching its own services.
