Testing alarm forwarding
Open a telnet session.
Connect to the TCP/IP socket that is specified in the <AlarmSocket> tag of the DataMiner.xml file.
You should receive a message similar to the following one:
---id: 202871 previous: 202868 root: 202868---
-> Element (2) Philips IRD
-> Parameter (176): Audio Output Level
-> Alarm Type : Dropped
-> Value: 12
-> Severity: Minor High
-> Status: Open
-> Time: 2012/07/18 19:26:44
-> Userstatus: Not Assigned
Only raw alarms are forwarded via TCP/IP sockets. Alarm messages generated by the DataMiner Correlation engine, for example, are not forwarded via TCP/IP sockets.
