Get parameter or memory value
For this script action, you must first indicate what is to be retrieved: a parameter or a memory value. The further configuration options depend on this first choice.
For a parameter get
In the first underlined field, keep Parameter selected.
Click the next field to either add an existing dummy element or create a new dummy element.
For more information on creating dummy elements, see Creating a dummy.
Choose the parameter to be retrieved. For a dynamic table parameter, also specify the index.
Specify the destination variable.
This functionality can also be used to get the value of a matrix crosspoint. To do so, specify the parameter as “matrix [matrix size]” and select the input and output.
For a memory value get
In the first underlined field, select Memory value.
Click the next field and either add an existing memory file or create a new memory file.
For more information on creating memory files, see Creating a memory file.
In the next underlined field, specify the number of the value that is to be retrieved.
Click the final underlined field and either specify an existing script parameter, or create a new one.
For more information on creating script parameters, see Creating a parameter.
