Script actions
A script consists of a series of script actions (i.e. lines). These are represented in the Script section of the right pane. You can add or modify script actions at any time during script configuration.
To create a script action:
In the Actions section, click Add and select the action. This will add the script action below any actions that have already been added.
Alternatively, to insert the new script action between existing actions, right-click the location where you want to add it, click Insert, and select the action.
Further configuration options depend on the type of script actions added. For more information on this, see Automation script actions in DataMiner Cube.
However, for all script action, the following options are available with the buttons to the right of the action:
To move an action one position up or down in the list, click the up or down triangle. Alternatively, you can also drag a script action to a different position in the script.
To add a copy of a script action, click the duplicate icon. The duplicated script action will be added immediately below the action it is duplicated from.
To delete an action, click the x.
