Configuring SLA Compliance
To configure how many violations are allowed in an SLA or what duration these may have, it is necessary to configure SLA Compliance.
To configure SLA compliance, go to the Compliance Configuration page of the SLA element in DataMiner Cube. There, you can configure the settings detailed below.
Setting the total violation limit
Under Total violation, you can specify how long the SLA may be violated during the SLA window before it is considered breached. Two types of total violation can be configured:
  • Relative: e.g. 0.010 percent of the total window size
  • Absolute: e.g. 5 minutes
To set a relative limit:
  1. Set Maximum Total Violations Type to Relative, using the drop-down list.
  2. Enter the desired percentage under Maximum Total Violations Percentage.
  3. Confirm your settings.
    The maximum total violation time will appear as a percentage next to Maximum Total Violation Time.
To set an absolute limit:
  1. Set Maximum Total Violations Type to Absolute, using the drop-down list.
  2. Enter a unit and value under Maximum Total Violations Unit and Maximum Total Violations Value respectively.
    The maximum total violation time will appear next to Maximum Total Violation Time.
Setting the violation count limit
Under Violation count, you can specify how many violations may occur before the SLA will be considered breached. For example, if Violation count is set to 2, the SLA will only be considered breached when 3 violations have occurred.
To set a maximum number of violations, enter the desired number in the box under Total Violations Before Breach.
By default, this field is set to Not used. To return the field to the default value, use the Not used checkbox.
Setting the limit for a single violation
Under Single violation, you can specify how long one single violation may last before the SLA is considered breached. As with the total violation limit, you can set either a relative or an absolute limit.
  1. Set Maximum Single Violation Type to Relative, using the drop-down list.
  2. Enter the desired percentage under Maximum Single Violation Percentage.
    The maximum total violation time will appear as a percentage next to Maximum Single Violation Time.
  1. Set Maximum Single Violation Type to Absolute, using the drop-down list.
  2. Enter a unit and value under Maximum Single Violation Unit and Maximum Single Violation Value respectively.
    The maximum total violation time will appear next to Maximum Single Violation Time.
