Deleting a low-code application
You can delete a low-code app from within the app or from the DataMiner landing page.
From the DataMiner landing page (supported from DataMiner 10.3.0 [CU10]/10.4.0 onwards):
Hover the mouse pointer over the app icon until you see the ellipsis ("...") button.
Click the ellipsis button and select Delete.
Click Confirm.
From within an application:
From DataMiner 10.3.0 [CU11]/10.4.2 onwards:
Click the user icon in the top-right corner and select Edit.
Click the user icon in the top-right corner and select Delete app.
In the pop-up window, click Delete.
To delete the current draft version of the app instead, click the icon next to the user icon. This draft version gets created as soon as you click Edit, so selecting this option will never remove a previously saved version.
Prior to DataMiner 10.3.0 [CU11]/10.4.2:
Click the garbage can icon next to the user icon.
In the pop-up window, select to delete the entire application, and click Delete.
You can also select to delete the current draft version of the app instead. This draft version gets created as soon as you click Edit, so selecting this option will never remove a previously saved version.
To view, add, edit, delete, or publish low-code applications, you need to have the necessary user permissions under Modules > User-definable apps as well as the DataMiner web apps user permission.
