URL data
You can link a component to data in the URL without relying on specific components in the dashboard or app.
To link a component to URL data:
  1. Select the component you want to link to a URL.
  2. Access the URL data:
    • From DataMiner 10.3.0 [CU21]/10.4.0 [CU9]/10.4.12 onwards: In the Data pane, go to URL.
    • Prior to DataMiner 10.3.0 [CU21]/10.4.0 [CU9]/10.4.12: In the Data pane, go to Feeds > URL.
  3. Locate the URL data you want to use:
    • Data category: Only available in the Dashboards app. This category includes various URL categories such as Booking, Object manager definition, EPM selection, Element, Number, etc. Prior to DataMiner 10.4.0 [CU11]/10.5.2, these categories can be found directly underneath URL in the Data pane.
    • DMAIP data object: Available from DataMiner 10.4.0 [CU11]/10.5.2 onwards. This data object allows you to pass the hostname and the IP port from the URL to a component.
      For example:
      URL DMAIP value
      https://myaddress.skyline.local/dashboard/#/db/SLC/QA%20tables.dmadb myaddress.skyline.local
      https://localhost:4200/#/db/SLC/QA%20tables.dmadb localhost:4200
  4. Drag the URL data to the component.
When the dashboard has a specific component that contains the same data as the URL, that data will overwrite the data from the URL.
