Clock (analog)
This component displays an analog clock that indicates the current time.
In the Component > Settings tab, the following settings can be configured for this component:
To use a custom polling interval for this component, in the WebSocket settings section, clear the checkbox and specify a different polling interval (in seconds).
In the General section, the Type box allows you to select whether the current DataMiner time should be displayed (i.e. the time of the DataMiner server to which you are connected) or the local time (i.e. the DataMiner client time).
Alternatively, from DataMiner 10.3.8/10.4.0 onwards, you can make the clock display the date and time in a specific time zone. To do so, in the Type box, select Custom time zone, and then select a time zone in the Time zone box.
In the Component > Layout tab, the following options can be configured:
The default options available for all components. See Customizing the component layout.
Show seconds: Select this option to include the second hand in the clock.
Show date: Select this option to display the date below the clock.
