Example of an Asset Manager configuration file
This is an example of an Inventory and Asset Management configuration file:
<?xml version="1.0"?>
<AssetManagerConfig xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<DatabaseConfig>GTC</DatabaseConfig>
<Schema>GTCDB</Schema>
<DisplayName>Global Telecom Corporation</DisplayName>
<HandlingDMA>103</HandlingDMA>
<RootTable>channel</RootTable>
<Security>
<Group name="Administrators">
<Read base="allowAll">
<Deny>TableX</Deny>
</Read>
<Write base="denyAll">
<Allow>TableY</Allow>
</Write>
</Group>
<Group name="Operators">
<Read base="allowAll" />
<Write base="denyAll" />
</Group>
</Security>
<Tables>
<Table name="table1" displayName="Table 1" displayColumn="column1 (column2:column3)" />
<Table name="person" displayName="person details" displayColumn="Name" >
<ColumnRelations>
<ColumnRelation sourceColumn="addressID" onDelete="PromptLinkedRemoval" />
<ColumnRelation sourceColumn="employeeID" onDelete="DenyLinkedRemoval" />
</ColumnRelations>
</Table>
<Table name="filtered_table" displayName="Filtered Table" displayColumn="Name">
<Filter>
<![CDATA[column1 = value1 OR column1 <= value2]]>
</Filter>
</Table>
<Table name="ordered_table" displayName="Ordered Table" displayColumn="Name">
<Order definition="column1 DESC" />
</Table>
<Table name="ca_modul" displayName="CA Modul" displayColumn="Name">
<Columns>
<Column name="column3" displayName="Service ID" width="123" />
<Column name="column1" />
<Column name="column2" />
<Column name="column4" />
</Columns>
</Table>
<Table name="ip_pool" displayName="IP Pool" displayColumn="IP">
<PathsToFollow>
<Path>NONE</Path>
</PathsToFollow>
</Table>
</Tables>
<AllLinkedDataOrder>
<Table>ird</Table>
<Table>channel</Table>
</AllLinkedDataOrder>
</AssetManagerConfig>
