Configuring Mobile Gateway to communicate with an SMSEagle device via HTTPS
It is possible to set up communication with an SMSEagle device via HTTPS. To do so:
  1. Open C:\Skyline DataMiner\Mobile Gateway\Config.xml.
  2. In the <HttpGsm> tag, add the following subtags:
    • UseHttps: Set to "true" to enable HTTPS.
    • RequireValidSsl: Set to "true" to require a valid certificate on the SMSEagle device (recommended). In that case, the HttpGSM.Location tag must contain "smseagle" instead of the IP address of the device.
  3. Make sure the port attribute of the <Location> tag is set to the port on which the SMSEagle device is listening. This will most likely be port 443.
    Example of the <HttpGsm> configuration in Config.xml:
    <HttpGsm>
      <Location port="443">smseagle</Location>
      <Schedule>3</Schedule>
      <UseHttps>true</UseHttps>
      <RequireValidSsl>true</RequireValidSsl>
      <SMSEagle user="user" pass="pass"/>
    </HttpGsm>
    From DataMiner 10.2.0/10.1.5 onwards, you can also add the unicode="true" attribute to the SMSEagle element to make the SMSEagle device use Unicode characters when sending text messages.
If <RequireValidSsl> is set to false, no further configuration is required. If this is set to true, follow the procedure below:
  1. Make sure the DataMiner Agent trusts the default server certificate of the SMSEagle device:
    1. In your internet browser, go to https://\<IP address of the SMSEagle device>.
      If an error message appears, telling you that the site is not secure, ignore it.
    2. Click the warning triangle to the left of the URL bar, and click certificate. A window will open.
    3. Go to the Details tab, and click Copy to File.
    4. Click Next, specify a random folder and a file name, and click Save.
    5. Open the Microsoft Management Console. To do so, press WINDOWS+R, type "mmc", and press Enter.
    6. In the Microsoft Management Console, press Ctrl+M.
    7. In the Add or Remove Snap-ins window, select "Certificate" from the Available snap-ins list, and click Add.
    8. Select the following options:
      • Computer Account
      • Local Computer
    9. Click OK to close the Add or Remove Snap-ins window.
    10. Under the Console Root, go to Certificates (Local Computer) > Trusted Root Certification Authorities > Certificates.
    11. Right-click the Certificates folder, and select All tasks > Import.
    12. Select the file where you saved the certificate details. This will load the certificate into the certificate store.
  2. Update the Windows hosts file:
    1. Open C:\Windows\System32\Drivers\etc\hosts.
    2. At the bottom, add a line with the IP address of the SMSEagle device, followed by a space and the word "smseagle"
      Example: 10.3.1.41 smseagle
    3. Save and close the hosts file.
  3. To check if the certificate was correctly installed, open an internet browser, and go to https://smseagle/login. If no "invalid certificate" errors appear, the certificate was correctly installed.
  • In production environments, it is recommended to use the domain certificate of the network (e.g. smseagle.skyline.be) and to generate a server certificate for the SMSEagle device that is trusted by the root skyline.be certificate.
  • The SMSEagle firmware supports HTTPS as from version 2.7.
  • When an SMSEagle device with firmware version 3.32 is used, because of an issue with this firmware version, it is not possible to retrieve the signal strength.
